Good morning all!
Firstly I just wanted to say hi.
I am a new owner of a 2003 2.5 with only 59k and 2 owners. It was a friend of a friend that put me on to it as one of the front springs had broken and they couldn’t move it out of the garage and knew I liked the Z4 and I decided I wanted a project…
New springs and shocks fitted and the car is now sat as it should be I moved on to the dreaded roof issue. Several swear words and hours later the motor was removed and in a terrible state. New motor purchased from eBay (not genuine) and fitted but roof still not moving. I then got concerned that when fitting the motor to the reservoir that I hadn’t done it correctly so purchased a further motor with new reservoir so I knew it was sealed correctly and should be a simple process. How wrong I was!
The roof latches and unlatches as it should, the motor sounds like it is working but doesn’t move the roof. The motor times out and has the red light on the switch. Have I missed something obvious or could there be something else to look for?
I have read that several people have fitted these ‘cheap’ motors with success but wonder if I should have purchased a genuine used part?
Any help would be greatly appreciated!
Fantastic forum which I will hopefully be able to load some photos up when the car is finally done!
Thank you all in advance.
