New battery - HELP!
ATPDK
Midtjylland
My Bosch S4 in my 2003 3.0i is dead. I'm looking for alternatives - the best for the price!
I have a hard time finding Bosch dealers here in Denmark. But I do have an easier time finding Vatra and Exide. Are any of these can be recommended? Must be at least 74 AH, or ...?
Wat is AGM batteries?
Soooo confused :cry:
I just bought a battery for my VW from these guys http://www.tayna.co.uk/Car-Batteries-C48.html Excellent service , good range of batteries and value for money. Not sure whether they will deliver to Denmark though?
Try Biltema , there might be one near you they seem quite cheap on there with a 3 year warranty
http://www.biltema.dk/da/Bil---MC/Bilreservedele/Elsystem/Batteri/Bilbatteri-forseglet-vedligeholdelsesfrit-8021005/
Excellent with a Danish link - thank you!
But their own brands (which you link to) get bad reviews.
I look at the following - any experiences? But it is expensive!
http://www.thansen.dk/product.asp?c=10146257961&n=-1985555946&pn=-1021772768
How many AH you should I at least go for? And is there a maximum? Anything else I have to look for?
The BMW dealership that I use where I live sells Exide batteries as replacement batteries for BMW's. They are expensive and are consider to be a high quality battery.
AGM (absorbed glass mat) batteries are in short a different technology to your conventional flooded cell.
Rather than having electrolyte just sat inside the battery it's (as the acronym suggests) material soaked with the liquid.
The benefit is that you've more flexible mounting options (some manufacturers say upside down as well, just they don't recommend it if you can help it) as well as not needing to vent the batteries.
Plus they're maintenance free.
I run an XS Power d5100 in my car. It's good for 57ah and it does the job just fine. I wouldn't get worried too much on the reserve capacity of the battery (the ah rating) and would concentrate more on the cranking amps of the battery as that will be a better indication of how well it will start your car (because after that, the alternator will supply most of the power for the car's needs).
To add to that, the battery (surprising to some) was the first mod for my car, and carried out the day the car came home (within hours infact). It's just the piece of mind for me that the battery itself can deliver more than I'd ask of it even though the reserve capacity is less (this isn't an issue as such given the car has a CTek charger hooked to it most of the time)
AGM technology has now come to the point where all those modified big diesel trucks are comfortably started with the entry level 20ah agm batteries from both stinger and XS power.
The only downside is that the cost of these batteries are more expensive.
As for the brands you've mentioned, I've always been a huge fan of Bosch batteries (though I've never owned one as I've in the past had an Optima RedTop and the aforementioned XS Power) but Varta have has some solid reviews especially in high demand situations such as with car audio applications (one of my friend's has sworn by Varta Batteries in his 2kw audio setup).
I know it's a lot and a quick google search will yield more technical info, but just sharing my experiences with different battery technologies.
I have been put off by Bosch seeing the number of failed units on the various forums. So yes, an S4 and S5 have a 4 and 5 year warranty, but they all seem to fail well within that time and need replacing (under warranty), just a hassle I would not want.
