I have bought a new 2006 Z4 and am loving it but have the following issues:
1) The car is bluetooth enabled and i have tried to pair my phone but it does not seem to recognise it. I hit the R/T button the steering wheel and even with Bluetooth on my phone activated it comes up with 'no phone'. I understand this may be as the phone is not supported but am i going about it the right way? I have yet to cycle through all my old phones so hopefully one works...
2) My car still has run flats on it and over lumpy tarmac the wheel is wrenched side to side to an extent (almost like bad torque steer)- i have ehcekd the tyre temps (put them back to 34 psi all round) but it still does it meaning over broken roads i really need to hold the wheel tight.
3) The soft top is working fine up and down and stowes correctly (which i understand can be an issue) but sometimes when putting the roof down, the latch seems to stick on the left hand side. If this happens i usually press the close button again until the red light goes off, then try again and this seems to fix it. I am concerned this may be an issue needing fixing althgouh luckily the motor seems to working perfectly - concerned the motor may be taxed when the roof is stuck which may lead to motor issues down the track.
Would greatly appreciate your feedback on these as otherwise i am loving my time with the car so far.
