Need To Change Battery
Action Jackson
South East
Hi all,
Trying to fix a few problems i've been having with my zed and the battery is the next step :cry:
So every website i go to asks me to punch in my reg and a list comes up of batteries. The majority of them are AGM START STOP batteries.
e.g https://www.halfords.com/motoring/b...art-stop-agm-12v-car-battery-4-year-guarantee
As far as i'm aware i don't have start stop function in my zed? (at least ive never experienced it!)
Just had a chat with the local halfords who say i don't need the AGM battery (when their website and their live chat tells me i do). Yet saying that, after they put my reg in their system they tried telling me a owned a 3 series, so i don't know what to believe anymore :headbang: ... after the conversation with them im even more confused :|
I know i need to register the battery when i finally do get (the right) one, possibly at halfords, i got told they couldn't register it, my dad was at the store, AT THE SAME TIME and got told they could? :rofl:
Car Details: BMW sDrive30i roadster 3.0
Battery details: 12V 70Ah 760A
120RC 760CCA (SAE)
Also seen on other forums that BMW White batteries are NOT AGM, and black batteries ARE AGM, I've got a black battery in there at the moment ... so AGM is the route i need to go?
TL;DR: Halfords have confused me so much, i don't know what battery to put in my car anymore! :sos:
(Quite determined to go through halfords as my dad can get trade discount :thumbsup: )
Sorry, I can’t help you with the battery problems. But I’ll be interested to know what others think,as I’ve got the same model as you, 3.0 s drive, and I think I may need to replace the battery soon as I occasionally get the car on ramp sign and then the small triangle on the dash.
I would and have AGM, lots of electrics on this car with the roof.
Pay whatever, i paid about £160 from Halfords for AGM and coding.
OP, if your car doesn't need an AGM battery I wouldn't fit one!
My 3.0Si had what seems to have been it's 1st ever new battery last December on it's 10th birthday at 81K miles! It only cost £95.32 + VAT fitted (I would have fitted one myself, but it was at the garage for a fault code diagnosis). :(
The AGM battery on my 123d (with stop/start) only lasted 4 and a half years and 55K miles. Back in 2012 it cost over £250 from a BMW Indy by the time it was coded - Sytner had quoted £300! Sadly if the car has stop/start I don't think fitting anything else is an option. :headbang:
I’ve coded the stop/start to remember it’s last state as it was driving me nutz :x
With that strain removed, a normal battery should be ok to fit I reckon.
a couple of different opinions :P
After reading up abit more about it, I do like the sound of the AGM.
Also worth noting i make lots of short little trips (i only work a stones throw away) which apparently this battery is better for.
I'm not overly bothered about the lifespan, 4 years sounds like it could be worth what it provides? :erm: Halfords has a 4 year warranty on batteries, so if anything should go wrong before that, not much of a problem :)
Pretty straight forward. Buy a 70ah AGM battery like the one you had and there is no critical reason to go through the battery registration process. Just fit it and it will be fine.
Fitting a non-agm is OK too but I would then recommend battery registration as the charge voltage is slightly different.
Stop/start drove me nuts on that 123d too - especially when the starter motor died at 6 and a half years! :headbang:
Whatever route you take (and I'd go AGM), register your battery our you'll risk reducing it's lifespan due to overcharging.
My car had it's original AGM battery when i changed it. It was at least 7 years old and worked fine. Only replaced because of the boot cycling problem which i thought was a battery problem, but turned out to be a manufacturing broken wire problem.
I remember buying lead acid batteries and would just about last two years before they died. Usually just after the two year warranty had expired.
I think the later 4 cyl cars have Stop/Start, not sure about the earlier 20i's but the 6 cyl cars don't have it. I have a 35i, have just changed the battery. The old one was the original, with BMW stickers. It was a lead acid battery and lasted almost 8 years.
I suspect it would have lasted longer, but I was getting warnings about electrical drain and Euro Car Parts had a sale on last weekend, so picked up a replacement Bosch battery for £100.
Fitting was easy, the only thing that needed resetting was the clock - although the trip counter reset to zero.
I do have Carly to register the battery, but the replacement was the same type/amp hours so I don't know if it was really necessary.
It probably is if you change from lead acid to AGM or vice-versa.
Cheers, Dave
I'd avoid AGM at all costs if that is an option! :o
The AGM in my 123d didn't last 5 years, but the non AGM in my Z4C managed 10 years and the replacement cost less than half the price!
That doesn't seem to represent progress to me. :?
That may have been the stop/start tearing the guts out of the battery rather than the agm cell being useless to be fair? :?
I'm sure it may have been, but isn't that why cars with stop/start got fitted with AGM batteries that were allegedly able to cope with that sort of usage? But they clearly can't! :lol:
Does it really matter which is the weak link anyway?
Stop/start and/or AGM batteries are best avoided wherever possible IME.
In fact stop/start is probably best avoided at all costs - my 123d also killed it's starter motor within 6 years. :headbang:
I don’t mind stop/start if it’s coded out, leaving the alleged beefed up components to do a normal job instead should give them a long life! :P
Maybe, although I don't think the components are beefed-up - after all the warranty is only 3 years! :lol:
I'd still much prefer to buy a car that isn't built with stop/start - that way you don't need to replace things designed to just about outlast the warranty. :P
I've got stop/start on my other car and frankly I wish I could turn it off permanently, regretfully I have to do it each journey. This car is fitted with an AGM battery which I believe has to be fitted with s/s whereas my Z I have a normal battery and no s/s.
Point is if you have s/s then make sure you fit the right battery even if you can turn off s/s. Being the suspicious type I believe eventually the day will come when the MOT will decree if s/s is fitted it must work.
Yes, being somewhat cynical myself I'm sure they'd love to!
But fortunately I'm not sure how they can tell. :)
It only operated on my 1 Series when it was up to normal temperature, didn't when the outside temperature was below a certain number and wouldn't when there was heavy electrical loading - there are probably other parameters I never noticed!
Different cars. Different systems. Try a non AGM in a start stop car.. see how long it lasts :rofl:
