Need Some IT Help
Nova2k7
 Halifax - West Yorkshire
Ok so ive got virgin media fibre optic broadband with a 60mb connection. now when i use the superhub with an network cable and connect it directly to my laptop im getting the full 60mb download speeds when testing however, wireless test have been coming back with me getting not even 1mb speeds!!! after a quick 15 minute call to VM its now gone up to 30mb on wireless tests! However, they are now saying that my wireless adaptor in my laptop will no go up to 60mb and this is why its not getting the full 60mb over wireless! now the adaptor in my laptop (a Sony VAIO under 12 months old and costing over £800) says it can handle up to 150mbs and all the drivers are current! this is the name of the adaptor atheros ar9285! any ideas guys?
That's an 802.11n chipset so you need to check that both the laptop and router are set to use 802.11n, If they are running b/g you'll only get up to 54mbps.
Also check you have the latest driver for your laptop.
Hey Novak! Only thing I can think of are signal strength, and the wireless frequency. If there's other wireless networks it can sometimes interfere. You can get a tool to show you all wireless networks and their frequency, then manually set yours to something different.
Also worth checking that the router is set to accommodate all wireless standards e.g. 802.11a (11mbps), 802.11g (54mbps) and N(150mbps).
Hope this helps!
Sean
Beat me to it!
I'd say make sure your wireless access point - in this case likely the Superhub is set to WPA2.
I can't think of the top of my head the exact setting - but the encryption type should be AES rather than TKIP for full speed.
Possibly some more settings to change, but I've never played with a Superhub so not sure what options it exposes.
This might help:
http://community.virginmedia.com/t5/Wireless-Networking/Superhub-Stupidly-Slow-Wireless/td-p/1207807
Quite a few people having issues with the super hub wireless by the looks of it, and the easy fix is to run it just as a modem and get a dedicated wireless access point :thumbsup:
well ive just logged onto the HUB and under the Wireless radio settings ive now changed it to "Up To 300Mbps" from the "144mbps" it was on before, this has seen my wireless test go up to 38-40mbps.
ive also now set the hub to WPA2-PSK[AES]
bluestreak56 said:
Could also be major interference on your wireless channel, try an alternative.
this is what i thought to begin with but i have no neibourghs! no other wireless networks are even picked up by my laptop or phone!
Sounds like you are running on the g standard instead of n. Check settings on wireless adapter properties on laptop and also on router settings. If they are set to auto try forcing settings to n instead.
Do you have any 3 phase overhead power lines near your house?
is this something to do with a setting on my HUB called "Greenfield Mode"? ive just turned this on.
Yep that's it. Your router will not waste it's time allowing for older a/b/g devices now.
Any better?
Any better?
well im using that sppedtest.net and i think its the slow servers rather than my connection! just need to find a decent server to use for the test as currently getting 1mbps again lol
any other speed test websites i can use?
How many walls between your laptop and the router?
Do you have the option of 5Ghz instead of 2.4?
My TalkTalk broadband max's out at about 2.7mb/s, so I'm jealous either way!
only the one wall, i live in a small apartment! yeah ive got the 5ghz option on the hub but not sure my laptop can use it?
30mb!!! I'd be over the moon if I could get 10mb where I live!
Scorp.
Scorp.
lol but i pay for 60! its the principle!
