I bought my 04 Z4 3.0 two days ago, car has 60k and its a 1 owner car, but warranty is expired, dealer offered me to purchase the 4yrs/48k warranty from GE for $2500 and $200 deductable, I'd like to hear some comments about this warranty to see if its good or not, thats the list of what they'll cover:
ENGINE
Engine block; cylinder head; rotor housing; oil pan;
valve cover; timing cover; all internally lubricated parts
contained within the engine; oil pump; timing chain,
gears and tensioners; timing belt and tensioners;
balance belt; variable valve camshaft adjuster; intake
and exhaust manifolds; harmonic balancer; engine
mounts; water pump; flywheel; and flexplate.
TRANSMISSION, TRANSAXLE & TRANSFER CASE
(Automatic and Standard)
Case housings; housing covers and pans; all internally
lubricated parts contained within the housings; torque
converter; viscous coupling; vacuum modulator;
and transmission mounts.
DRIVE AXLE (Includes Transaxle and 4WD Vehicles)
Front and rear drive axle housings and covers; all
internally lubricated parts contained within drive axle
housings; axle shafts; constant velocity joints and boots;
driveshafts; universal joints; flex discs; driveshaft center
support bearing; driveshaft yokes; 4WD engagement
actuators and motors; and 4WD locking hubs.
FRONT SUSPENSION
Upper and lower control arms; upper and lower
ball joints; hub and wheel bearings.
STEERING
Steering gear; rack and pinion housings, and all
internally lubricated parts contained within the housings;
power steering pump; power cylinder assembly.
FUEL
Fuel injectors; fuel pump; all turbocharger
or supercharger internal parts and housings.
COOLING
Radiator; electric cooling fan motor and relay;
fan clutch; fan shroud.
INTERIOR CLIMATE & COMFORT
Air conditioning compressor; clutch; pulley, and its
mounting bracket; accumulator; receiver dryer;
evaporator; condenser.
BRAKES
Master cylinder; vacuumor hydro booster; wheel cylinders;
calipers; equalizer and distributing valves; ABS electronic
control unit, wheel speed sensor, and exciters; ABS
proportioning control valves; high-pressure hydraulic pump.
ELECTRICAL
Starter motor; starter solenoid; alternator and its
mounting bracket; voltage regulator; wiper motor;
headlamp; turn signal and windshield wiper switches.
POWER TECH & ELECTRONICS
Manual and power window regulators; power
antenna motor and mast; power trunk or tailgate
actuator and motor; power headlight door motors
and actuators; power sunroof motor; convertible top
lift motor; power seat motor transmission and cables;
power mirror motors; cruise control assembly;
speedometer; odometer; fuel gauge; tachometer; volt
and amp gauge; temperature gauge; trip computer
control module and display; factory installed
electronic combination entry and anti-theft devices;
transmission and transfer case control modules;
ignition control modules; fuel injection control
modules; fuel injection sensors; electronic air
conditioning control head and module.
SEALS & GASKETS
For all components listed.
ENGINE
FRONT SUSPENSION
STEERING
FUEL
COOLING
BRAKES
ELECTRICAL
SEALS & GASKETS
