Hi,
So I know when I had the Sump oil gasket done it required new alloy bolts, all guildes online seem to use the bolts again on these items, do they need to be replaced?
11428637821 Gasket
11428637820 Gasket
Bolts, how many of each if these need to be replaced?
11427540759
11427540763
11427540758
11427543327
2 x 07119905591
Thought if im having the above done, would it be worth doing the below
https://www.ebay.co.uk/itm/395664254578?_skw=bme+coolant+flange+n52&itmmeta=01JJRX7YZTCAC75Q79XWRY0E3V&hash=item5c1f6d6672:g:NPIAAOSwMM5m3qK9&itmprp=enc%3AAQAJAAAA0HoV3kP08IDx%2BKZ9MfhVJKmt%2FW4t7hIy7wJqWLAA%2FiUPiaIAddE9w%2F6jxU5xI%2FFc0JghDQXze%2Fksgjeu%2FpLFnfPCcC0YEtZEsKGnlOk1p7fFK6QdbJKxKAIdGfNraBZ4u3OhZiDGrvAOcE0MWQaTgKSUFWqH3qDrclwp%2FuDnywZKT6A7YZ%2B9yMMa5CzjZ1k7e%2FUO4J7bn4OXPVGsWMgjIEZkEc5c6u%2FnpFzK589%2B4ZmoWf%2B1H7BkGf7u4%2FlTUJg8BcaY3SVv%2FlshSAQw9aTOCJQ%3D%7Ctkp%3ABk9SR4jwn52WZQ
There seems to be allot of variations in the above, just curious how common the plastic ones are at failing?
Would a spring band hose clamp be better then a jubilee clip and what size would be needed?
https://www.ebay.co.uk/itm/304783468431?_skw=spring+band+hose+clamp&itmmeta=01JJRXGXN2GFCVAV88P5RWJKB3&hash=item46f682a78f:g:d1QAAOSwHclj0864&itmprp=enc%3AAQAJAAAA0HoV3kP08IDx%2BKZ9MfhVJKk9DHDr3MqTHd5vdmY1uE87uiafmayHl%2FnQN4h1pOAzki9qmszd3tjwlLSb7fP%2BKbiV9HSvhlbzICaB%2BIlaueiBkmrCeQwTIa%2FaJiyaqJGVVTn2Tg4lQgTA0H9hbE61akOQ8EuX%2FaOwZE8oJYUp7nnEsoS24gKk8UPhKu76hCZTDXg3vQgyYV%2BWK6XxB7mp2mJw0Sljul374h6SipH8do2hoWGCeV%2F4uu7b%2Fec2cezECqiZsUpj2nJ%2FvOoLyOpj%2BEs%3D%7Ctkp%3ABlBMUNraw52WZQ
Also I should look at changing the serpentine belt 11287628651, but what about the tensioner / pull and bits?
11428637821 Gasket
11428637820 Gasket
11427540759
11427540763
11427540758
11427543327
2 x 07119905591
