N52 CCV Replacement
Scooba_Steve
NW London & Somerset
Seeing some oil consumption with no apparent leaks, car runs pretty well with no code issues, tailpipe is sooty and there is a little suction when opening the oil filler cap. I estimate the consumption is about 200ml per 1000miles.
So with that in mind I'm hoping a CCV replacement will solve the issue.
Having not taken the manifold off are there any tips anyone can offer?
For the CCV I can source one and all the pipes but would appreciate any other help that can be offered, TIS doesn't seem to have anything for the CCV.
I lessened my cars oil usage after putting a little sea foam through the ccv pipe & into the valve cover outlet the ccv pipe connects to, i also introduced some into the engine oil filler cap so it could clean up the oil rings on the Pistons as this can also occur after a period of oil burning as the engine ingests more oily vapours through the inlet manifold if the ccv starts to become bunged up.
It definitely improved my car.
Regards
Does that resolve the cause though? I'm happy to just replace and then forget for a good many thousand more miles but can't find any instructions for the N52 CCV.
yes, i found that my cars oil usage dramatically improved after my "treatment" so id say it did resolve the cause.
What sort of use does your car get & how often are you changing the engine oil? These things can have an effect on the ccv.
regards
regards
Mine is a daily with 10 mile each day commute and trips to London once or twice a month. Oil is changed before 10k with 7.5 aim, which has worked out about a 6-8 month interval. Track days a couple of times a year with a change before.
Ed Doe said:
have to ask... what is the CCV?
Hi, the ccv vents crankcase gases from the engine & routes the vapour into the inlet tract and condenses the rest back to a liquid, routing them back to the sump.
Regards
The "CVV" (crankcase ventilator valve) is easy to do. It condenses vapors and send them back to the sump. There's also a rubber diaphragm/valve inside which gets gummed up.
Perhaps try searching for E46 how to's.
I bought mine from Euro, it's genuine/original.
Make sure to replace the throttle body seal, don't reuse it.
As far as I know the n52 ccv has no diaphragm inside & works on the vortex principle, it's possible to disconnect the pipes & blow through them to check for blockages with the route into the sump producing a satisfying "glugging" sound :oops:
Regards
I can confirm there is a rubber (red) diaphram and spring acting upon it, the vortex/condensate/collector is the part on mine which was coked up.
As for changing the unit: the pipes are clipped on and easy to remove. There is one pipe that points forward (the tricky one) this DOESN'T clip on. It's held with a bayonet just like a light bulb. It's the shorter of the pipes, it points forward and goes up to the manifold. Unclip it at the top end and rotate 180 anticlockwise until it points down, then pull forward. Usr rubber grease to help the idle control valve and Disa back in place. You will have to remove the dipstick tube, if your engine oil is full to max jack the right side of the car slightly to prevent spillage. Make sure to clean around this tube because as you pull it up the dirt will drop into the oil. And don't forget the throttle body seal, they cost £8. ON mine the only pipe which had gone brittle was the one going to the cam cover/CVV. £18. I warmed it prior to fitting to get the bend relaxed.
I think you're getting models mixed up Gary, this is about the ccv on the si models-the n52 engine uses different parts compared to the m54 engine including the fact it doesn't have a dipstick :thumbsup:
Regards
This might shed some light. Its not a Z4 but you can get the basics from it as it is a N52 engine.
[youtube]https://www.youtube.com/watch?v=McXpFdVQliA[/youtube]
Bit late for me but might help someone else :thumbsup:
Just to complicate things a little more, the CCV was redesigned on the black top N52K. Supposedly more reliable but perhaps less serviceable!
Don’t you need a whole new cam cover with those engines because the ccv is incorporated inside it :cry: ££$$
Don’t think so Rob according to this.... https://vanos-bmw.com/product/11127552281-bmw-valve-cover-repair-kit-n52-n51-n52n-n52k
I know that if using genuine parts it’s repair by replacement, not sure about the aftermarket parts on offer :?
