pokeybritches
Sounds like ESS is testing an N51/N52 supercharger. Previous to this, no one knew how much pressure the engine could withstand, since it has a cast crank and uncommon block construction.
Here are the RUMORS: The kit is being tested to 10 psi, but the production kit will run 7 psi. The kit is non-intercooled. ESS is testing their kit to 30k miles prior to release. The variable stage intake makes minimal difference in final power numbers.
