N20 golf tee mod question
jamesgarbett
 South Manchester
Were you able to access the hose easily on an N20? It seems easier to access on the 6-cyl models where there is a tailpipe on each side of the car rather than twin tailpipes on the left hand side
It almost seems like I would need to remove the rear bumper to access it and cap it off?
No need to remove the bumper, you can reach the pipe easily.
jamesgarbett said:
Did you need to jack the car up?
I didn’t bother, you can reach the vacuum pipe no problem. Get on the ground & look up, you can see what needs to come off :?
Thanks Rob I could see the pipe but couldn't really see how to reach the parts to cap them once the pipe is removed - just seemed like the bottom of the bumper was in the way - will have another look tomorrow
I did the mod back when I had a 35, but I have to say the drone on the motorway drove me nuts! Rest of the time I loved it.
When I got the 35is, I didn’t bother and i rarely missed it. I think the 35is sounded better anyway.
Basically, just be be aware of the motorway drone.
However, from memory I didn’t need to jack car up. In fact I think I just kinked the pipe with a cable tie.
Thanks I feel like it might be easier on a 35 than the N20 due to the location of the exhaust pipes - just basing that on some youtube vids I've seen - but will try tomorrow
I can't seem to find any information about this mod, can some kind soul add a link please.
Hi, you pull the vacuum pipe off the actuator & cap the parts off - it’s that simple :thumbsup:
Make sure you seal both ends of properly as it routes back to the brake servo reservoir!
Totally agree with this post
