M Machine monkey Lifer In the shire Oxfordshire Feb 5, 2013 #42 No problem buddy I will make the door pins
B ben g Lifer Essex Feb 5, 2013 #43 i've noticed you keep using the term OME to describe original equipment manufacturer, which actually should be OEM.
B ben g Lifer Essex Feb 5, 2013 #45 Jonny essex said: ben g said: i've noticed you keep using the term OME to describe original equipment manufacturer, which actually should be OEM. Click to expand... OME = original manufactures equipment Click to expand...
M Machine monkey Lifer In the shire Oxfordshire Feb 6, 2013 #47 ben g said: i've noticed you keep using the term OME to describe original equipment manufacturer, which actually should be OEM. Click to expand... I should start using OME Original Monkey Equipment!!! I like it
