Hey everyone, I got myself a BMW Z4 2003 3.0i earlier with 100k miles on it. When I got the car, the brake pad, tire pressure, and the airbag light was on. I figured it was probably just a fuse/sensor so I didn't mind it as much. I also noticed that the radio is stuck on "PHONE" and I can only switch between that and the clock.
It bothered me a little bit because I want some music on my car, found a forum post that said I just have to remove the radio fuse and then put it back on. So this is what I did exactly, removed fuses 47, and 50. I turned on the car with the fuses removed, then turned off the car, put the fuse back in, then started the car. It didn't resolve the radio stuck on phone issue but now new problems arose, here's a list of them.
- Turn signal lights work but green arrow does not light up and no clicking sound, I just noticed the lights were still working through the reflection.
- I can't put the roof down anymore, the button lights up red as I press the button then immediately goes away as soon as I stop pressing the button. It does not flicker like other people's issue.
- My remote key doesn't work anymore. I can't unlock/lock the door using the remote. I have to manually unlock/lock the door.
- After starting the car, if I turn off the engine then remove the key, the cluster lights remain turned on, no warning lights or anything, only the speedometer and the gauges. Took me a couple of tries restarting the car to get them to turn off.
After a while my remote key suddenly works again. But after testing out the car again, as i step out of my vehicle, the remote key will stop working again. Then after a while, it will work again lol.
I really need help, what are your thoughts? Do you think it could be the battery or another fuse? If possible, can you also help me out with the brake pad, tire pressure, and airbag lights? Thanks for helping me out.
