Mtech Front Discs + Pads £60
cyrilsneer88
 birmingham
Selling a pair of Mtech grooved and drilled front discs inc. pads. Bought through the tech eBay page a few months ago but never got round to fitting them and we are now unfortunately selling the Z4.
originally bought for £89.99. willing to accept 60£ o.n.o as a quick sale for whoever can collect.
original advert : https://www.ebay.co.uk/itm/BMW-Z4-2-5si-03-09-Front-Drilled-Grooved-Brake-Discs-MTEC-Pads/302091697585?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
BMW Z4 2.5si 03-09 Front Brake Discs Drilled Grooved With MTEC Pads
Front Discs Specification:
Vented - Studs 5
Disc diameter 300.0mm
Disc thickness 22.0mm
Overall height 51.5mm
Centre diameter 79.0mm
Minimum thickness 20.4mm
Please note all discs come in pairs.
If your fitment is not listed check our other items in our shop.
After purchase PLEASE email/message/phone us with your model details so we can ensure you have purchased the correct items for your car.
Additional Information
MTEC Brakes brake discs can be supplied in drilled and grooved, grooved only, dimpled and grooved or drilled only, all at the same price!
Key Benefits of MTEC Discs
The grooves help deglaze the pad and prevent fade which occurs when the pad and disc gets too hot!
The holes help to keep the discs cool and dissipate heat!
The grooves also help to channel water away from the disc surface!
Stopping distances are reduced!
They add the finishing touch behind alloys!
Longer disc life!
Reduced weight!
Black attractive finish
No modifications needed to fit! Straight swap for your old standard discs!
Best results will be seen with premium branded pads, although these discs are fully compatible with budget pad types.
Won’t fit the 3.0si (LCI). Will fit 3.0i pre facelift. Not sure about 2.5si
