Wonder if you guys could help me out, I have an old 205 gti as a track day car. It's time for it's mot but the car has a few little issues which I'm unsure if it will affect the mot.
It has a couple of gauges not working, water temp and oil temp as far a I can make out. All the others are fine.
Other issue is that the radiator fan is not automatic, it needs to be manually turned on via a switch on the dash, it went through it's last mot with it's previous owner with this mod so I'm not worried so much by this. I was hoping to have a local Mechanic sort the car but he's on holiday till the end of the month, id like to get the car back on the road now if possible and have him sort the gauges later.
Car runs fine (it will when I put an earth cable on the alternator) and doesn't overheat or have any problems as far as i can tell, I was planning on just changing the oil / coolant / brake fluid / put some legal tyres on it and check the obvious things pre mot - will it pass or am i best waiting to have the mechanic look at it in 3 weeks?
