Snigger. He may need a doctor for that!enuff_zed said:and consider changing the wehole thing?
Ah bugger! Good spot. Guess you'd say it was a cock up. :rofl:Pondrew said:Snigger. He may need a doctor for that!enuff_zed said:and consider changing the wehole thing?![]()
Sorry, couldn't resist. Carry on![]()
enuff_zed said:OK, just looked on Realoem and it seems the clutch and brake pedal hang on a common bracket. If it's the pivot pin that is worn then it seems you'd have to replace that whole thing. But if it's the hole in the brake pedal that is worn then maybe you can swap the pedal. What I can't tell is if there's a bush in that hole? Would be great if it was just that worn or missing and an easy replacement.
Sounds like a lower arm change then. Same applies, if it were me I'd probably change the lollipop at the same time. Once worn I've found they tend to get worse fairly fast, so no immediate rush, but something to consider while the weather is good.birdy_z4 said:enuff_zed said:OK, just looked on Realoem and it seems the clutch and brake pedal hang on a common bracket. If it's the pivot pin that is worn then it seems you'd have to replace that whole thing. But if it's the hole in the brake pedal that is worn then maybe you can swap the pedal. What I can't tell is if there's a bush in that hole? Would be great if it was just that worn or missing and an easy replacement.
Suspension
Drivers side offside front lower (front arm inner bush)
Jasonn said:I had the clutch pedal on our X3 suddenly go on a Friday evening, it dropped to the floor and I couldn't start it as the pedal wasn't depressed. Thought it was the slave cylinder so got it towed to a garage (my indy had no slot as I had to drive down to Devon on the following Monday morning.
Garage said the pin fell out and just needed "popping back" - £170 later I've got to Devon and it happened again - found an indy who'd seen this happen before - £320 for a new pedal box fitted. The pedal is nylon (or similar) with no bushing/reinforcement so the pin will wear it out - appalling design
Are they interchangeable with an E89?enuff_zed said:Barry (Umfaan) is breaking an E85 atm. He may be able to help with the bits you need.
:headbang: I'm just going to go back to bed and start the day again! :roll:Pondrew said:Are they interchangeable with an E89?enuff_zed said:Barry (Umfaan) is breaking an E85 atm. He may be able to help with the bits you need.
This is the E89 section. I think Mr Birdy has an E89.![]()
:lol:enuff_zed said:I'm just going to go back to bed and start the day again!
Tuesday is the only day I actually go into the office now, so I'm surreptitiously trying to read the forum in a small corner of my screen. Obviously I'm not paying attention!Pondrew said::lol:enuff_zed said:I'm just going to go back to bed and start the day again!
Lucky for you I ain't your boss. It would be P&O for you :lol:enuff_zed said:Tuesday is the only day I actually go into the office now, so I'm surreptitiously trying to read the forum in a small corner of my screen. Obviously I'm not paying attention!
Have had a stern word with myself!
enuff_zed said::headbang: I'm just going to go back to bed and start the day again!Pondrew said:Are they interchangeable with an E89?enuff_zed said:Barry (Umfaan) is breaking an E85 atm. He may be able to help with the bits you need.
