MOT advisories / suspension bushes
TJC46
As per the title. Mot advisories as follows
MOT from 2016
Advisory notice item(s)
•Nearside Front Lower Suspension arm has slight play in a pin/bush rear bush (2.4.G.2)
•Offside Front Lower Suspension arm has slight play in a pin/bush rear bush (2.4.G.2)
MOT for 2017
•slight movement in console bushes
Is this a regular thing on the Z4 ?
Been onto the eurocarparts web site and there are a few bushes to chose from.
Can anyone point me in the right direction from the above MOT info, or is it a bit vague i.e not enough info to pinpoint exactly which bush.
Or should I just renew the lot, again if so which ones.
Here you are
https://www.eurocarparts.com/suspension-bushes
Thanks guys
Tom.
As common a problem as cracked rear springs. It's your wishbone bushes, known as lollipop bushes
Edit this product from your link https://www.eurocarparts.com/ecp/c/BMW_Z4+Coupe_3.0_2006/p/car-parts/suspension/suspension-and-steering/suspension-bushes/?618110295&1&1439ca61a2fd806db914090a1f7a644f2f7994e8&000437
