Hi everybody - I'm considering a 2006 E85 near to where I live but the recent MOT advisories have me worried -
Coil spring corroded Both rear (5.3.1 (b) (i))
Offside Front Coil spring corroded (5.3.1 (b) (i))
Both rear shock absorbers corroded
Rear Sub-frame corroded but not seriously weakened (5.3.3 (b) (i))
Nearside Front Suspension arm pin or bush worn but not resulting in excessive movement Rear bush (5.3.4 (a) (i))
Suspension arm corroded but not seriously weakened Both rear (5.3.3 (b) (i))
Nearside Suspension component mounting prescribed area is corroded but not considered excessive outer sill (5.3.6 (a) (i))
Offside Suspension component mounting prescribed area is corroded but not considered excessive outer sill (5.3.6 (a) (i))
Brake pipe corroded, covered in grease or other material Both rear (1.1.11 (c))
Brake pipe corroded, covered in grease or other material Both front (1.1.11 (c))
Tyre worn close to legal limit/worn on edge Both rear (5.2.3 (e))
Rear Anti-roll bar corroded but not seriously weakened (5.3.3 (b) (i))
There's no mention of corrosion in any of the previous MOTs so I'm wondering if its just perfectly normal for a 20 year old car and the MOT checker was just overly zealous?
If it does all need sorting is it a big expensive job, and should I just walk away (the cars already at the top of my budget)
Thanks for any advice anybody might be able to give.
