Mixing engine Oils
benv6
 Berkshire
I am due for a service and I will be going for the 5w40 instead of the 0w30 (Castrol Edge)
My question is that I do have about 2l some 0w30 left from last service, and was wondering if I can mix it with the new 5w40 ?
Hi, as the mad professor says-its fine as long as they are both synthetic & the grade difference wont matter :thumbsup:
Real bad idea to just change oil grades. Manufacturers specify oils grade and other factors for very good reason
benv6 said:
ronk said:
Why do you want to go 5w Ben?
I want to see what would be the MPG difference, I heard you would get better MPG with 5w40 :)
If that's your reason then you're going the wrong way, the 0w30 is a less viscous oil inducing less drag on the engine :thumbsup:
I would be surprised if you measured much difference though :?
Agree with Rob , , you are more likely to see a worsening of MPG going 5w40 & a twin turbo engine where oil is a real factor in keeping running temps down i would be spending more time choosing the right oil than deciding what grades :?
5w 30 will see you right , as for which brand ?
Do some digging & some reading but in my mind Millers is the one for both cold start & hot running cycles
I would be nice surprised if you measured much difference though :?
Agree with Rob here, don't follow the logic. Interested to know the result though.
Stick with the viscosity specified is the best advice and I would not mix oils unless absolutely necessary.
I won't mix screenwash!
As these chaps quite correctly say, don't mix them. Properly cheap skate thing to do...
Also, better MPG, you're going the wrong way in viscosity as is already said.
Finally, the only reason I've ever heard of people going thicker is to reduce any very slight misting/leaks that are showing on seals due to thin oil.
I've heard of oil burning problems being diminished by using thicker oil as well :thumbsup:
