Hello everybody.
So, here's the deal. I want to play MP3 from a USB key in my car. I have a Z4MR with sat nav, BT, phone and DSP options. I've already read almost everything there is to read about this on this forum and others. I've checked almost all solutions available, from the cheap Chinese kit to the full Alpine setup, including Dension and other Dice kits. All these solutions point to the same conclusion : it is perfectly doable, it will use the MFSW, it will display the MP3 titles on the GPS screen, and if i go with the cheap Chinese solution, it won't even be that expensive at all.
So, here i go : i order a Yatour kit with the DSP module. I receive it and go an about installing it. I remove the carpet in the trunk, fumble a bit with the cables and the amp... and can't find the CD changer wiring. I get inside the car, remove as much panels as i can without removing the central storage unit... no sign of the wiring. I remove the stereo head unit, nothing at the back either.
Finally, i have a friend of mine check the original list of options using the car VIN. The answer is there: option 692, CD changer pre-wiring, is absent. As it turns out, my car is a very early Z4MR, and it would seem that very early models here, in Continental Europe, were not fitted with the wiring as standard.
So my question now is simple: were should this wiring be plugged to ?
I know that i'm looking for two plugs: one for the coaxial wire for the DSP, and one small three pins plug for the CD changer command. But i couldn't find anything on the amp or on the "central command module" which would fit this description.
Does anyone has access to this information ?
Thank you very much.
