Missing a bit off my Zed
Marlon said:
MefiEcosse said:
Is this what you need?
Found this in the boot of mine after buying the car!
I’m not sure tbh - let’s see what others say, if it is that would be great 😀
My understanding is that they are handed so will depend what side it is!
If there's no way of telling I'd cover the postage to find out?
7057452 is the drivers side headlamp washer, if that's any good to you? part numbers here:
http://www.realoem.com/bmw/enUS/showparts?id=BT52-EUR-04-2003-E85-BMW-Z4_30i&diagId=61_1604
After losing one of my covers a while ago and now doing more motorway miles (so more need to regularly spray windscreen what with the dirty splash back from the roads) i removed the fuse for the headlight washer system last week so i don't have to risk them raising up at high speed. Simple and quick to do and will replace prior to MOT. Fuse no. 40 which is a 30A one if i remember correctly. Unfortunate that you've lost the whole unit though.
does that fuse control only the headlamp washers? also, is that particular fuse behind the glove box? Thinking about doing this with mine, as I simply don't see the point in them. they use so much washer fluid, compared to the washer jets for the windscreen.
As far as I'm aware, yes. I did a bit of research and seems a common approach. I was worried it might spray but just not raise but it looks like removal of the fuse stops the whole process.
Adamski's fuse guide was really helpful:
https://z4-forum.com/forum/viewtopic.php?t=38888
Lovely stuff, will give it a go tomorrow, cheers :thumbsup:
Just to confirm, removing no. 40 fuse (30a) works :thumbsup: excellent stuff. I assume it'll need to be put back in for the MOT? I only have halogens, so unsure whether it's a case of if headlamp washers are installed, they need to function as normal?
Not a problem if so, only takes a few seconds. I just hope I remember next year :lol:
Id have to check but I think Carly also allows you to turn them off. I know it definitely lets you set them to operate less frequently as I set mine to the min it allowed of 9 to 1 or something like that. Ill try and have a look later. I wouldnt mine turning mine off as they piss me off for the reasons already mentioned.
To be honest Ben's pulling the fuse method is quicker, are the headlight washers the only thing on that fuse Ben?
I believe so. I had a quick look at the fuse card and couldn't see anything else that uses fuse 40.
The Carly option sounds good, but they will still activate whenever you have your lights on, after every single start up, I think. That's how they work from factory anyway.
This time of year, I'm using my washers in both the journey to and from work, every day, so that's twice that the headlamp washers would be activating, every single day. Drives me mad as it leaves the front end looking a right mess :cry:
Totally agree about them making a mess of the front end, drives me mad after a wash, drives me insane after I've polished it.
How much real difference do they make anyway? The headlights (even the xenons) are sh!te!
