I have send this email to AP racing UK
My reply
On the AP website it is stated the following:
• APF403 - General Competition Pad. Not suitable for road use. Easy to bed, predictable and repeatable performance with good bite & friction. Consider where Raybestos ST41 / ST43, Ferodo DS3000 or 4003 are currently used.
• APF404 - Excellent High Performance Road and Track pad. Consistent performance, low wear, disc friendly, low noise, low dust, low fade, good feel. Consider where Ferodo DS2500, Pagid Blue RS4-2, Pagid RS421 or Carbo-Tech XP10 are currently used.
When I ordered my AP racing Z4M kit it was stated on the AP website that the APF404 brake pads would be included. When I received my kit there was a set of Ferodo DS2500 with them. I always thought that APF404 is a AP branded Ferodo DS2500. I'm I wrong?
The reply from AP was the followingHi, I have a BMW Z4M with a full AP racing kit on the car (fitted for track days). The brake pads that are now fitted are the Pagid Blue (RS 4-2). It's time to change them into a fresh set. When driving on the street they squeal a lot. They told me that the Pagid RS 4-2 should be silent. So how can I reduce this squealing? Are there anti-squeal shims available for using the Pagid RS 4-2 on AP Racing calipers? Also, could I use copper grease on the back of the brake pads to reduce braking noise? Is it okay to use copper grease in combination with AP calipers? Some people say that you can not use copper grease on brake pads with AP calipers, because this will damage the seals and metal. Is this true?
So they are saying that Pagid pads are not 100% designed for use with AP calipers & discs? First time I heard this...Dear Sir BMW Z4M AP Racings UK factory produced front brake kit # CP5575-1010.
Using CP5570 6-pot caliper that uses 2off Alun bolts to retain the brake pads: -
Uses pad family # CP5070D54
Caliper type can be verified from web link: http://www.apracing.com/ProductDetail.aspx?ProductID=2763
You might find that the Pagid pads are only 51mm deep across the braking face and not the 54mm that the disc is designed for. If so then that won’t help brake noise!
If you want a road pad that works well on the track then use APR pad # CP5070D51-APF404.
Copper slip if used sparingly won’t affect the CP5575 caliper seals because they are not exposed to the pads back plate. but It isn’t the best method to cure pad squeal.
We do list a squeal shim that cam be stuck on top a back plate. Shim # CP3558-35 but at £8.00 each they are expensive. Because the shim is a sandwich of steel, rubber and adhesive they don’t survive track temperatures!
My reply
The short reply from APIs the APR pad #CP5070D51-APF404 exactly the same pad as the Ferodo DS2500? The Ferodo DS2500 are the pads that are deliverd with my AP racing kit when I ordered new. I never fitted them, because other AP racing user adviced me not to this, because in their opinion the DS2500 does not preform very well on track days.
Now I'm confused; they are saying that similar to the APF403 would be the Ferodo DS2500? On the AP website it is stated that APF403 is a general competition pad...and the Ferodo DS2500 is far from a competition pad.No
APF404 is our own material and is NOT the same as DS2500, similar to that would be APF403!
