Hi all
My Zed seems to be misfiring when sat on idle, I got a diagnostic done and here are the results. Wondered if any of you could point me in the right direction now.
DTC 279C -Thermostat characteristic cooling. Activation.
-Intermittent
DTC27C3 -Thermal oil level sensor
-Intermittent
DTC2883 -Mixture adaption, bank 1
-Intermittent
DTC2883 - Mixture adaption, bank 2
-Intermittent
DTC281D -Alternator serial interface
-Intermittent
DTC2747 - Misfire cyl 4
-Intermittent
DTC2892 -Misfiring
-Intermittent
DTC2742 -Misfire cyl 1
-Intermittent
DTC2743 -Misfire cyl 5
-Intermittent
DTC274E -Misfire on more than one cylinder
-Intermittent
The guy I spoke to at the garage said it could be one of those sensors at the top of the list which could be causing the rest of the problems and advised that I start there. Does this sound right to you? If I was to start at the Thermostat at the top of the list would this be the correct part to get first? http://www.ebay.co.uk/itm/BMW-Z4-E85-3-0-i-2003-02-M54-B30-306S3-170kW-THERMOSTAT-/272005638986?fits=Model%3AZ4&hash=item3f54ccab4a:g
rsAAOSw0HVWEPBS
What would you try first? Anyone got any advice?
Thank you.
-Intermittent
-Intermittent
-Intermittent
-Intermittent
-Intermittent
-Intermittent
DTC2892 -Misfiring
-Intermittent
-Intermittent
-Intermittent
-Intermittent
Thank you.
