Mfsw help
Palmer666
Hi all I have an 03 z4 3.0 and have a chance to fit mfsw but I would like to know if I have the wiring and if not how I do I fit it. Someone mentioned there was a way to check for wires without taking the wheel off, but I can't find the post anymore. Cheers all.
Cars built after Sep 2003 came with pre-wired slip rings. If your factory build date was before this you'll probably need the famous 'retrofit cable'. A foot long piece of wire with a couple of plastic plugs that BMW will probably charge twenty odd quid for these days! Still an easy DIY though, have a look in the How To section of the Forum, there is a very detailed guide. :thumbsup:
Hi all again have managed to find some Diy instructions on how to change wheel and have seen what the extra wiring I need looks like, but I can't find any descriptions of where the wire needs to be plumbed into so the buttons will work. It may just be the fact I'm new to forum but I just wondered if there is anywhere I can see pictures.
cheers all.
Board Index > E85/E86 How To > Interior > How to retrofit M steering wheel with multifunction control
Loads of pics in the how to thread at the above location sorry on an iPad so cannot post a link ATM.
The retrofit cable simply splices into a couple of wires behind the LCM (the lightswitch on the right of the instrument binnacle). The cable comes with pre-terminated plugs on one end that just push into the slip ring and a couple of little scotchloks you can use to splice into the wires at the back of the LCM.
Now you'll get a few people saying never use scotchloks and always solder then shrink wrap instead but tbh for this application scotchloks are fine as long as you deploy them correctly.
Palmer666 said:
Thanks that makes me think the job is possible even for a newbie like me. Cheers
:o Ohhh! An optimist! :? Remember Murphy's Law? "If it Can go wrong, it Will go wrong" - Good Luck anyway :roll:
Very quickly the wind in my sales has been diminished lol na just joking I have spoken to bmw they quoted a week wait for bloody wires :(
Hi there
I'm intrigued as to which part no. you ordered as I am wanting to do the retro fit as well. I got some conflicting info when I called my local BMW dealer with the part no .65 71 0 304 942/3. The dealer basically said that this kit was only for the Z4 built after Sept '03 and that anything before that the kit would not be suitable for. I take it that your car is built before Sept 03 and that to make this compatible you simply require the addition of the wire sold separately. Interestingly I was quoted a price of £203 from Peter Vardy Edinburgh and £169.17 from Soper BMW Lincoln or £192.59 which I assume is with the addition of the cable/wiring. These were back order items meaning there would be no returns if I ordered incorrectly which is why I'm being so thorough.
