4 4Z WMB Member DALY CITY, USA Jul 27, 2008 #1 I will be replacing the Mass Air Flow on my 2003 Z4 3.0i. Do I have to reset anything after the installation? Please help/ suggest.
C Curtis Active member Yatton Jul 27, 2008 #2 You don't have to reset anything but make sure the ignition is switched off when you unplug the old unit or the ECU will record a code for low voltage or open circuit at the MAF sensor.
S Shipkiller Veteran Jul 27, 2008 #3 You don't have too, but resetting the computer will reset the high and low setpoints used on the MAF... Just disconnect the battery cable for about 10 min...
