luckyboy1228
It's drivable but the RPMS go revving and dropping while ideal-ing, and the engine just dies. Its rough hence the misfiring cylinder(s). I replaced the MAF sensor and hoped it was the culprit. I sprayed brake cleaner over the intake air lines to see if there was a leak in there: It checked out fine.
I'm now thinking it could be a dirty ideal control valve? I'm truly lost!
I'm open for suggestions for what my next move should be. I cant afford to take it to a shop, now that I'm unemployed-- and the car was no warranty.
codes
Stored:
P0102 mass or volume Air Flow "A' Circuit Low
Pending:
P0101 Masss or Volume Air Flow "A" Circuit Range/Performance.
P0302 Cylinder 2 Misfire Detected.
P0313 Misfire Detected with low fuel.
codes
Stored:
Pending:
