Digidick said:Just spent 30mins changing the gearbox oil on my 2003 2.5 E85 and it’s well worth the time and £22 as it now feels much smoother and the 1st to 2nd change is much improved.
I used Millers 75w-80 TRX Fully Synthetic and it took around 1.1ltrs.
Mikeyay said:There is a sticker on side of my gearbox saying do not drain, lifetime oil or something like....2.5si 6 speed. Does this sound about right??
My thoughts also, mine has just clocked 80k and I plan on changing it.Magicarcher said:Mikeyay said:There is a sticker on side of my gearbox saying do not drain, lifetime oil or something like....2.5si 6 speed. Does this sound about right??
BMW have this thing about changing oil as infrequently as possible, hence their 18-20k for engine oil changes and their lifetime transmission and diff oil policy. I read somewhere that it comes from "green" pressure in their domestic market and competitors doing the same (must confess I never validated it). I am sure they have life tested their transmissions without oil change and they are fine. But my take is oils deteriorate with age due to the high temperatures they encounter combined with particles of mechanical debris that are inevitable due to wear. If you are the sort of person that changes your car frequently it is probably best to stick to BMWs recommendation. But if you plan on keeping the car longer, then changing the oil (providing you stick to the same spec) can do no harm and the transmission may be smoother and last longer. I changed the "lifetime" transmission oil on my BMW Mini at 50k and the gearchange appeared smoother.
mr wilks said:Digidick said:Just spent 30mins changing the gearbox oil on my 2003 2.5 E85 and it’s well worth the time and £22 as it now feels much smoother and the 1st to 2nd change is much improved.
Big Millers fan here & that's the stuff ive always used , their engine oil also worth considering![]()
Digidick said:mr wilks said:Digidick said:Just spent 30mins changing the gearbox oil on my 2003 2.5 E85 and it’s well worth the time and £22 as it now feels much smoother and the 1st to 2nd change is much improved.
It was you that made me choose Millers, found an old post of yours.![]()
mjennings23 said:Used the same myself and find it excellent once warmed up a bit. Still a bit stiff on the cold mornings however, but 10 minutes driving and it's perfect.
ph001 said:http://r.ebay.com/tBhVRP
Magicarcher said:I am sure they have life tested their transmissions without oil change and they are fine.
markalp said:As BMW think that gearbox/diff lubricants are lifetime fluids does this mean they are never changed when Inspection I / II are performed. If so I'm getting it booked in to get those done next week, I just assumed it would be part of the major service, whoops I mean Inpection II (I really must get up to speed on all this BMW terminology)
eddiemunster said:Magicarcher said:I am sure they have life tested their transmissions without oil change and they are fine.
Transmission oil is more about heat dissipation than lubrication, so running it without oil for a short period of time wouldn't really prove anything: it'd be noisier and it'd over-heat fairly quickly. "Oil for life" is a nonsense in engineering terms, what's closer is "It'll do, for a lifetime", but personally I'd change mine every 40k-50k/3-4 years, particularly on those transmissions with LSDs as oil weight can affect their efficiency.
