Pbondar said:With boxes like the ZF8HP I'm at a loss to understand what this 'manual' issue is?
The only thing from a behaviourial view that distingusihes that box from a manual are:
1) No clutch pedal
2) No H pattern in manual mode (just up n down)
Can someone explain what the issue(s) are?
1) No clutch pedal
More than that, driving a manual car well is enormously rewarding. Pulling away rapidly from stationary without excessive wheel spin, clutch slip or bogging down; smooth, rapid upshifts under maximum acceleration, perfectly coordinating hand and foot whilst snicking across the gearbox; heel-and-toe downshifts using two feet on three pedals to enable rev-matching whilst braking hard into a corner, clipping the apex already in the correct gear and then accelerating smoothly back up through the gearbox. None of that is possible when pulling a paddle. Not to mention the fun of a hill start on a steep, slippery road.Smartbear said:Pbondar said:With boxes like the ZF8HP I'm at a loss to understand what this 'manual' issue is?
1) No clutch pedal
It’s purely personal opinion but the auto even in manual mode doesn’t mechanically change the gears when you move the stick, you’re just operating a microswitch which can feel a bit lacking. The manual gearshift actually moves the cogs and you can feel it - It’s this difference in mechanical involvement that separates the two :?
BMWZ4MC said:More than that, driving a manual car well is enormously rewarding. Pulling away rapidly from stationary without excessive wheel spin, clutch slip or bogging down; smooth, rapid upshifts under maximum acceleration, perfectly coordinating hand and foot whilst snicking across the gearbox; heel-and-toe downshifts using two feet on three pedals to enable rev-matching whilst braking hard into a corner, clipping the apex already in the correct gear and then accelerating smoothly back up through the gearbox. None of that is possible when pulling a paddle. Not to mention the fun of a hill start on a steep, slippery road.Smartbear said:Pbondar said:With boxes like the ZF8HP I'm at a loss to understand what this 'manual' issue is?
1) No clutch pedal
BMWZ4MC said:... Not to mention the fun of a hill start on a steep, slippery road.
1) No clutch pedal
Pbondar said:The only thing from a behaviourial view that distingusihes that box from a manual are:
1) No clutch pedal
I can imagine! I did the opposite on a very light motorbike on a Malaysian island when I was 18. Determined not to get bogged in soft sand on a slope, I gave it way too much gas and was last seen disappearing into the rainforest on one wheel. It didn’t end well :rofl:PaperSniper said:BMWZ4MC said:... Not to mention the fun of a hill start on a steep, slippery road.
Indeed, that is a lost art! I used to ride with a motorcycle group in and around Memphis, TN. There was a particular hill near the river that I avoided when leading as most could not master foot down, gas on, clutch out without stalling! And stalling a heavy motorcycle is even more exciting than stalling a car on a steep hill!![]()
