maintenance schedule 03 z4
freddie
 IL
Hello all,
I thought my internet search skills were good, but I can't find a copy of the manuf. rec. maintenance schedule for the 2003 Z4 3.0
I'm out of warranty and need to keep up with all the normal maintenance--does anyone have a document showing the recommended items and mileage for each?
THANK YOU!
Yes, I couldn't find what their recommend service intervals were. I mean, I know all the things I have to do, just not what mileage is recommended.
Or, I should say, I THINK I know everything that has to be done, but a list would help so I don't miss anything.
THANKS!
BMW Inspection I
Undercarriage
Change oil and oil filter while engine is at operating temperature.
We recommend BMW High Performance 5W-30 Synthetic oil, p/n 07 51 0 017 866
Check transmission for leaks.
Check rear axle for leaks.
Half shafts: Check for leaks at flexible boots.
Visually check fuel tank, lines and connections for leaks.
Check condition, positioning, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks. Check p/s fluid level; add fluid if necessary.
Check overall thickness of front and rear disc brake pads using special tool. Record results. If replacement is necessary*:
Examine brake disc surfaces. Clean brake pad contact points in calipers. Grease wheel centering hubs. Check thickness of parking brake linings only when replacing rear pads. Record results.
Check brake and clutch system connections and lines for leaks, damage, and incorrect positioning.
Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc.
Check parking brake actuation. Adjust if necessary.
Check all tire pressures (including spare - except M3, M5, Z8 and Alpina). Correct if necessary. Check condition of tires (outer surfaces [left/right]), tread wear and pattern; in case of uneven tread wear readjust wheel alignment if requested.*
Note:If requested rotate all four road wheels as instructed and rebalance.*
Inspect entire body according to terms of rust perforation limited warranty (must be performed at least every two years).
Engine Compartment
Read out diagnostic system.
Check level of brake and clutch fluid in reservoir. Add fluid if required.
Replace brake fluid every 2 years (timing interval begins from vehicle's production date).*
Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
Check air conditioner operation.
Replace microfilter.
Note: reduce replacement interval in dusty operating conditions.
Reset Service Indicator.
Body/Electrical Equipment
Check battery state-of-charge, and charge if required.*
Check lighting system, i.e., headlights, foglights, parking, back-up, license-plate, interior (including map reading lights), glove box, flashlight, illuminated make-up mirrors, luggage compartment lights.
Check instrument panel and dashboard illumination.
Check all warning/indicator lights, check control.
Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
Check wipers and washer system(s);wiper blades, washer jet positions.
Check condition and function of safety belts.
Recharge or replace batteries for remote controls in all vehicle master keys.
Check central locking/double lock.
Check operation of all latches.
Check heater/air conditioner blower fan, rear window defogger.
Check rear view mirrors.
Visually examine the SRS airbag units for torn covers, obvious damage or attachment of decals, decorations or accessories.
Final Inspection
Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission (except M3, M5, and Z8).
BMW Inspection II
Undercarriage
Engine Compartment
Replace intake air cleaner element.
Note: Reduce replace interval in dusty operating conditions.
Final Inspection
freddie, welcome to the forum... :thumbsup:
When you have a few minutes why don't you go over the "newbie" forum and introduce yourself and post up a picture of your Zed... :camera:
Wonder if we'll ever see him again, now that he wrangled the info he wanted... :| ..I wait until they introduce themselves before giving them all that info...drifters.. :tumbleweed:
The lady has a point..
Thats why in my techmanual post, I said "Registered Users"
Gott make the site grow........ :thumbsup:
But, this is why I like this site. EVERYONE is very helpful and does not come down on you if you ask a question like you were an idiot for asking. I am on a lot of other forums and sometimes getting info out of them is like getting 'blood from a stone'...
Most here know the only stupid question is the one not asked. This truly is a great Z community - wonderful people :thumbsup:
Well, thank you again for the kind replies--but to acknowledge the folks towards the end of the thread who were snarky, here goes:
I've lurked and contributed to many other car boards over the years, including other Z4 boards. I've never posted pics of my cars, mainly because I don't see that much difference between all of the other pics posted, so why add more of the same. Just my own opinion--I know many people like to see other members' cars, and more power to that!
If there's a problem with infrequent postings that directly serve a need, such as this original topic requesting help w/ maintenance schedules, please let me know and I will go elsewhere. I always contribute on boards when I have knowledge to give, but I don't have that much helpful/useful knowledge.
Thanks again,
Fred
You can get the "Service and Warranty Manual" from the dealership if you don't have it: that will tell you everything
I see. While I'm new to this forum, I've found most everyone here to be pretty friendly and some... down right funny. Of all the forums I have visited I feel most comfortable here. Welcome! :wink:
