Bad_Pritt said:I thought that the si with M-springs was as low as a standard Z4M? An si with standard suspension should be about 15mm higher.
mr wilks said:Bad_Pritt said:I thought that the si with M-springs was as low as a standard Z4M? An si with standard suspension should be about 15mm higher.
My thoughts too & ive just compared a measurement on front MC springs with front Si Sport springs ( both off the car ) & they are the same :?
srhutch said:Just checked the brochures, std Z4 1299, ///M roadster 1302mm
STD Coupe 1268, ///M coupe 1287mm
Mr Tidy said:srhutch said:Just checked the brochures, std Z4 1299, ///M roadster 1302mm
Just a thought, but would the different tyre profiles have an effect on overall height?
Bit it strange that there's only 3mm difference on the Roadster and 9mm on the Coupe. :?
