ihadablackdog
Sadly not what you dirty minded buggers are thinking
Question is this: what can be used to lubricate plastic thread?
I have a treadmill with an incline function, which hasn't worked properly for a while, it just stops raising and gives error 6.
I've stripped the whole treadmill down and removed the motor.
There is a central, metal threaded bar, and on that goes another threaded "sleave" made of plastic. The outside of that is threaded which goes into another sleave, which is metal on the outside but might be plastic inside.
I think it need lubricating because when its in the middle of the threaded length it screws easily, but when you get further out (say, the first and last third) it gets difficult to screw. The actual central threaded bar moves fine, its the bits that are mounted on it that are sticking.
I'm thinking this extra resistance might be tripping something in the motor.
So, would silicon oil be ok? I bought a bottle of 100% silicon oil to lubricate the running deck and I'm sure it said it could also lubricate the motor, so would it be ok for plastic?
I don't want to use wd40 cos that dries out.
