Recently, as part of full cooling system overhaul, I obviously replaced all cooling hoses.
Everything else is working just fine now, but there is a small, although noticeable coolant leak, right where the lower hose connects to the radiator.
Even though the hose is definitely fully pushed into the radiator nipple (with a reassuring locking 'click'), the connection seems a bit loose. Some very small movement can be seen at the joint where hose connects to the nipple when moved by hand. Is it supposed to be this way or should the connection be super tight with absolutely no play at all?
The spare hose is from Gates, maybe there's something wrong with it. Both the radiator-side connection nipple and the hose look externally just fine. I'm wondering should I try to seal the connection somehow or buy a new OEM hose just to be sure.
