Morning all,
While I was under the car doing the prop rebuild I noticed a fair amount of oil had been coming through the bottom cover and the alloy reinforcement plate. On investigation I found 4 of the sump bolts were no more than finger tight. 3 were at the rear right (drivers in the uk) side and one near the front. All of them had oil seeping down the bolts. I have very carefully re-tightened to 8NM but not done the extra 90deg turn and hope that will fix the problem.
Has anyone else had this issue ? Just wondering if it is common on these engines or maybe poor workmanship sometime in the past. The engine seems perfectly smooth running with no odd vibrations that I can detect.
Apologies the picture is sideways - not sure how to correct that....
Thanks.
Thanks.
