Loose centre vent
Paradroid
 Lancashire
The centre vent above the head unit seems loose on my car. I can push it at the bottom and it moves in 4-5mm, then sits flush. But when I let go it moves back out again. It seems pretty solid though, it won't pull out much.
Normal or could I improve it?
Usually means the clips at the top arnt located correctly or are broken............
+1
Remove the vent and reposition (bend) the clips
Cheers all, will take a look at it.
Also noticed something is missing on the centre console near the edge of the drivers seat, there's a hole with a screw in it that looks like it should have a cover on it. Also noticed the screw has some paint missing so it's been undone. Not sure why that would be.
