hi, so had my 3.0si roadster a year or so now, apart from a window reg, water pump and 3 coils dying (the coils the same day) its been a brilliant daily driver, done about 15k in it so far but looking to make some changes.
While the ride is really good and very stable at speed it just doesn't quite cut it in the corners, factory bias towards understeer and lack of front end feel ruin what could be a very good sportscar.
I've picked up some poly RTABs and lolipop bushes and was planning a csl geo setup, but the bushes I have aren't offset for castor.....do I swap these bushes for the offset ones?
the car will be going for an alignment once these are fitted, now I have searched but finding conflicting info so I'm after input from people that have used csl specs on a normal Z with factory M-sport suspension, or any other alignment settings that have improved handling.
I've read people saying 0 toe on the front made improvements and taking out allot of rear camber made it more neutral.
is the added cost of the castor offset bushes worth it?
also I've heard of people using M3 ARBs, anyone who's done this, has is helped reduce some of the front end body roll without inducing more understeer??
i'm hoping improving the handling will make up for what it lacks in the power department and keep me amused
maybe even start doing track days in it.
