Take off the undertray with an 8mm socket, then undo the u clamps which is just 4 bolts. Slip the brackets off the bushes, then replace by hand. Simples.
Thanks for the 'how to'. Is it best to do this with the car on a ramp? It seems that with the car jacked up the bar rests on the bottom
of the 'U' bracket. Wouldn't it be a PITA to get the bracket back on if the wheels are off the ground?
Doesn't matter up or down so long as both wheels are loaded or unloaded so yes easier on stands to get some room to work. The bar is only under torsion when the wheels are at different heights. Otherwise the bar can swivel within the droplinks.
