Locked out. Very locked out.
Haro said:
If the gm5 is toast it won't trigger the the locks but it will allow the windows to be opened.
Yup, that's ok then.
GM5 toasted is one thing, 7-y-o offspring toasted is not good. :roll:
I’m impressed with your humanity bud!
By the time they get to 7 your financial outlay is already huge. Wouldn't want to throw that away would you.
To say nothing of the paperwork! :rofl:
Spoken like a true ex service stalwart
Imagine the paperwork
Just sat in my car and tried all sorts to see if I could help you. Unfortunately I'm stumped too.
I see what you mean when you say you can pull the inside lever, the lock button pops up, but the door does not unlatch (when it's already locked).
I think I'd be breaking a side window as there are quite a few on ebay or you could ask Autoglass to come and remove your front windscreen.
Best of luck.
I'm in, and got everything working as it should except lock /unlock on the fob. It involved boot shelf removal, key on a string (incase recovery was needed) some fine contraption and two people, one to manipulate blind, the other giving directions, then a rod through the window gap to push the key home and then turn it. Engine started, doors still locked. Then managed to open on the central locking button!
The contraption was basically pipe insulation with the key inserted in the end but poking out at roughly 90 deg to offer it up to the ignition. Then pushed in via the window gap.
Bloody hell!
I hope you filmed that?
If not, do it again! That is some fine work. To achieve it without coming to blows must have been something!
Yup! Next job..................... getting a Yorkshireman's wallet out of his pocket.
Should be a doddle now :poke:
Took a few goes and I'm still surprised it actually worked!
Thanks to everyone for their suggestions. And yes, having tried to get my 6'5" through the gap into the cabin, you wont be surprised to find out I didn't fit. Got my head stuck in the gap for a minute before I worked my big ears out of the way. Got bloody hot on the glass! Think I'd would have struggled to convince my lad to go for it!
