Little Red Riding Hood Part Out!
Bama_Z4
 Mobile, AL
I could not sort out the transmission issues with my Z4. I am parting it out to offset my loss. She's a 2004 E85 3.0 that otherwise ran nicely.
I have tons of parts. All of them are clean and are in good working condition. I live in Mobile, Alabama USA. Any part can be picked up there, or shipped. Just message me for a shipping quote, additional photos, or with any questions. All prices are OBO - I attempted to come up with prices to satisfy the rules but admittedly do not know the going rate for all of them. Most parts come with mounting bolts/nuts. Thank you!
• Body Control Module (BCM) 61356919275 $200
• Gas Pedal Assembly 6762326 $50
• Left & Right Tweeter Speakers & Trim $60
• Ignition Coil Wiring Harness $70
• Front Right Passenger Door Switch $35
• Engine ECU 7527730 $150
• Dimmer Switch $60
• Lower Dash Trim Panel $35
• Center Panel Heated Seat & Top Switch Assembly $70
• Alternator 7519618 $75
• Upper Cooling Hose 7514404 $40
• A/C Compressor 64526905643 $100
• Rear Center Consol Compartment $60
• Micro Power Control Module 55892110 $50
• Driver’s Seat Switch Assembly 61317036125 $50
• Driver’s Side Seatbelt Retractor 7016875 $60
• Driver’s Side Headrest 7059619 $45
• Lear Hifi DSP Amplifier 65126938189 $250
• Sport Mode Switch 6915010 $50
• Complete Engine Wiring Harness Loom $150
• Driver’s Door Switch Assembly 6955043 $85
• Climate Control Assembly 64114116540 $150
• Trunk Release Button 61318365579 $30
• Hazard Lock Button 61318368920 $30
• Windshield Wiper Motor 6912150 $75
• Wiper Arms 61617011763, 1764 $35
• Dash Trim Brushed Aluminum Set 7043967, 7043968 $130
• Passenger’s Side Headlight $400
• Intake Air Cleaner $90
• DISA Valve 7502275 $120
• Sound Generator Assembly 13747514863 $120
• Intake Sensor Tube & Intake Hose $80
• Secondary Air Pump 1172290702 7514953-02 $80
• Cooling Fan Motor, part of assembly 17427519704 $120
• TCM 7522980 260002642, $70
• Engine Covers $80
• Upper Radiator Trim 7062811 $100
• Dipstick, Guide tube, and attached Hose Assembly $50
• Throttle Body 3547502445-05 $50
• Windshield Fluid Tank and Pump 61667007970 $60
• Bosch Air Control Valve 0280140545 $50
• Fuel Rail w/black Injectors and Fuel Line 143982702 $70
• Intake Air Equalizer, Tubing, & Crankcase Vent Valve $100
• Intake Manifold 1439288 $200
Hi
Can I get first option on the airbag modules x3 please
Can you let me know the codes on each module, price and shipping to uk
Hi Winn, sure. I know about the two in the doors. Removed them. Where will I find the third?
bigwinn said:
Hi
bigwinn said:
Hi
Central one is behind the handbrake in the central tunnel
You can see it if you pop the coin tray out that’s in front of the rear console
Pop the oem codes up when you get a sec- cheers
:thumbsup:
bigwinn said:
Hi
To clarify, he means control modules NOT the airbags in the doors.
As stated, the centre one is underneath behind the handbrake. The other two are mounted vertically on the inner sills at the base of the b-pillars.
However, a note of caution to both parties. It seems some US cars have different part number sets to the UK, so check the part numbers first.
You may be in luck. Here they are. Ebay shows the main one selling for $300, driver's side for $200, passenger's side for $50. You can have them all for $400. If they are what you need, just message me your address and we'll work out shipping.rezize1.jpg
bigwinn said:
bigwinn said:
Hi
:thumbsup:
:thumbsup:
Cheers for the offer however they look totally different to EU spec cars
Sorry bud
No worries. They'll go on Ebay. Good luck with the search!
[/quote]
Sorry bud
[/quote]
Hey Bryce, I will soon. I have it on ramps in order to yank the motor. I'm keeping the braking components on (for obvious reasons) until I roll it it back down. When I do, I'll let you know.
D.Bryce said:
Hi Bama,
Do you have the dsc pump and electric unit ?
