Hi everyone, decided to upgrade the interior lights to LEDs. All good and much better than the yellow standard fit on my E89. Saved changing the dome and map lights to last, but they don't work. Changed the dome first and that worked initially but then tried the same bulb in the map bulb holder and nothing worked. Now all three lights do not come on. However, if you press the dome light switch, the footwells come on, which is as they should which means that power is getting through to the console, plus the small red lights are working but no LED. Does anyone have any idea what the problem, might be?
