One day on my 2003 E85 I noticed that my average MPG was down 3-4 MPG, car was running fine, and then the next day I got the "service engine soon" light. Read the codes and it was showing P0171 & P0174 both banks lean. I also looked at the live data and the long term fuel trims were both around +28%. I looked for vacuum leaks at all the usual places and found none. I smoked checked it twice and only found a small leak at the DISA valve, fixed but no change. Fuel pressure was good, sprayed brake cleaner everywhere I could reach with no changes. I then removed the intake manifold and found that the main vacuum hose from the manifold to the suction jet valve was hard as a rock and leaking. While I had the manifold off I refreshed the CCV and the cooling system while I had access and since everything was original. Put it all back together and went for a test drive but the long term fuel trims only decreased to +21% so better but still waaay bad.
I then remembered that all of my problems started after I filled up my gas tank. So with half of tank left I went and filled it up from another gas station and took it for a ride. The long term fuel trims went from +21% to +14%! I now knew that I was on to something. I drove the car until I had less than a quarter of a tank and filled it up again and took it for another ride. 30 miles later the long term fuel trims were now +5% and getting better!!!
The only thing I can think of is it was just bad or mislabeled gas. I would have never thought that gas would have caused a "lean" condition!!
