Leak?
bigwinn
Elite
 Lincoln UK
Site Supporter
Having a good look under the front today
I now know I have an oil leak from the top of the engine as it was dripping onto the exhaust
Is this the bottom end of the leak? I think this is the oil drain plug, right? This is if I’m correct sort of under that top end leak around the 5th cylinder?
Zoom in to the bolt/plug:
That looks like one of the sump casing bolts. On my car the undertray has a pull down flap for access to the sump plug.
Forget that sump bolt wouldnt be visible there so probably is the oil drain bolt. But where is the undertray
The photo is taken from offside front wheel well. So that’s the offside of the block underside
The trays and underside are still in place
