Lambda Sensor Part Check?
pHilli0
 Bedford
http://www.eurocarparts.com/ecp/c/BMW_Z4M+Coupe_3.2_2006/p/car-parts/exhausts/car-body-parts-and-car-exhaust/lambda-sensor/?710111860&1&d7a0c0f00c2f1b23e91d7c2a5a7f7bca11d7ce94&000210
Are these suitable to replace my 2 x POST CAT lamba sensors?
The description says
Exhaust System In front of catalyst, Length(mm) 950, Part Spec 5 wire
So I wanted to check as my pre-cat sensors are OK.
Phil, that ecp part is definitely pre cat, both from the description and also the 950mm length (this is the correct length for pre-cat).
You want post cat... BMW part #s
11 78 7837564 x1
11 78 7837565 x1
Afraid I don't know the Bosch code for them, but I'm sure with a little digging you can find that.
Thanks Tom, I was afraid they would be different front and back, glad I checked!
I know the OEM prices are about 210 each so I will have a hunt for the Bosch equivalent.
I sent those back from lamdasensor as I wasn't happy with the bosch stamp having been etched off. The chap tried to convince me they were real and would have been fine and I suspect they would have been, but member on here andy beech after much digging (thanks andy again :thumbsup: ) found a source from germany that did the correct genuine bosch sensor however the cable was 50mm longer, hence the different part #. It was impossible to get the exact correct BMW spec part for some reason. Anyway, I digress! try here
http://www.finjector.com/en/home/
I only did the pre-cat ones.
