Hi all, I'm at my wits end with this car currently and hoping for some help / advice.
I'm getting 29A7 Lambda sensor before cat bank 1 - no signal P0134.
After changing the valve cover gasket I didn't notice that the cable to the pre-cat lambda sensor wasn't in place and got slightly melted by the exhaust. I notice it quite quickly as I was checking for codes. A section of the wire was melted. I bypassed this section with some crimps. However I'm still getting the error. Bear in mind I'm clearly not an auto electrician.
Bank 1 sensor sits at 0.43 volts. The bank 2 sensor varies as expected. I have tested swapping the sensor plugs around and bank 2 still works fine.
I checked the fuse for the heater, actually all fuses in the MS45 box. Installed a new sensor. Tested that the heater is actually working.
I see 12V on the heater wire. I think the heater wire is brown and red/white.
On the signal wire, yellow I'm seeing 0.43 to 0.44 volts contantly. When I earth this wire, while the engine is running, I see the voltage drop to 0.00 in INPA. as I would expect. The same behaviour is present on the black cable in the twisted pair. This surprised me. Because i think this should be just an earth. But if the wires were shortling somewhere I'd expect to see 0.00 contantly.
I've tried clearing the codes and resetting the adaptations but the code just returns and the voltage doesn't flap.
I'm sure I'm missing something obvious.
Please help
Please help
