Right,
The saga is almost over. after countless discussions with KW (in which it cost me 60 quid for 6 M8 x 40mm studs) i finally got them, and fitted them.
if you have KWV3, without the camber mounts, heed my warning. you NEED to cut 1 stud for each side. as the camber mounts shown in beedubs pic show, are a lot thicker. the supplied studs WILL hit the bonnet (lucky i checked before slamming the bonnet!)
ideally if you want to replace the studs, you need M8 x 30mm. oh, and if you are unlucky like i have been, 4 of the 6 studs just spin before they reach the required torque, so have someone that is handy with a welder close.
once ive had mine spotted into place, i will finally get the cars geo sorted.
