Key issue and programming
I was wondering if it is only just my key or others too,
When I press the opening button long It opens the roof and lower the window, but when I press the close button nothing happen even if I hold it for a minute or so.
And Is it possible to program the car to close itself when I start driving it maybe at 10 kph?
Or is it possible to program it that when I open it, it turns the light on?
Thx for the help
Its possible to code remote roof close - although it should be already enabled :( (KomfortSchleissung_FB = aktiv in GM5 General Module).
Its also possible to enable auto lock at defined speeds (Usually 16km/h in Key/Car Memory)
Which light do you want to turn on? Do you mean incicator flashes? If so this is also possible in the GM5 Module also (QUIT_OPT_ENTSCH = aktiv) :)
What is that GM5 Module you mentioned?
Can I do it on my own or do I have to go to some kind of bmw dealer?
Thx for the reply :)
Some one with an autologic will need to programme them in.
There are a few other nice options available too while your at it (triple indicators - key assigned to memory seats etc).
Atleast here in the UK remote roof closure isnt enabled from the factory due to health and safety and most BMW dealers wont do it either. As before you'll need to find someone with an autologic or similar to unlock/turn on these options.
