Scooba_Steve said:Sounds about right.
So you have the outer indicator on as a running light (not Kosher in the UK)? I think you may be able to enable the outer as a marker which should come on when side/dipped are on.
It is mandatory here. DRL's have to switch off when headlights come on. I'm guessing it's the same requirement in the UK?stuartC said:I thought DRT's are supposed to turn off when you turn on your main headlights ? Isn't that the point of daylight running lights?
Scooba_Steve said:No idea what BMW Scanner is - I've only ever used NCS Expert.
enzed4 said:It is mandatory here. DRL's have to switch off when headlights come on. I'm guessing it's the same requirement in the UK?stuartC said:I thought DRT's are supposed to turn off when you turn on your main headlights ? Isn't that the point of daylight running lights?
