Fixed that for youEwazix said:If the system was any good (and the same/cheaper price than the alternative) everybody would fit it as OEM
Marvin-HHGTTG said:No - I believe there can be issues with the foam type filters screwing around with the MAF. They do give a little more induction noise however so I've read.
Nictrix said:If K&Ns are dripping with oil someone has not oiled it properly.
There is only supposed to be a light covering of oil on the filter not drenched in it.
Never had to clean one but there is a specific K&N cleaning and oiling kit to do this jobNeilP said:Nictrix said:If K&Ns are dripping with oil someone has not oiled it properly.
Mine wasn't dripping, but trying to clean it was a bit of a nightmare as all the debris and such was sort of stuck to the filter.
I'm left thinking that those air filter socks for the induction kits may be the way to go if anyone wanted a different air filter. Obviously a heat shield would be needed to minimise head soak.
Nictrix said:Never had to clean one but there is a specific K&N cleaning and oiling kit to do this jobNeilP said:Nictrix said:If K&Ns are dripping with oil someone has not oiled it properly.
mmm-five said:Fixed that for youEwazix said:If the system was any good (and the same/cheaper price than the alternative) everybody would fit it as OEM![]()
Or are you saying that anything fitted as OEM is the best that could have been fitted at the time![]()
Rory said:What always makes me laugh is people buying a cone filter, then taking the time to construct a heat shielding airbox around it.
Sooooo that's what your car had to start with then, an air filter in a box? lol![]()
cj10jeeper said:Cone is a red herring here. This thread is about replacing a paper panel filter with K&N
