Hi folks!
Yesterday finally I bought my E85 Z4 2.5i and want to say hi to everybody
My first thought of buying Z4 was back in 2012 but finally i chosed E90, but yesterday my little dream came true.
As I will drive it only on weekends (probably sundays only as my girlfriend works on saturdays) I wanted a 3.0i.
I found this well equipped with full service history 2.5i so I started to read about 2.5i vs 3.0i and the overal conclusion was that 2.5i has plenty of power and you can feel the difference between them only above 4k rpm, so I decided to buy it.
And I'm already a bit dissapointed
. The car pulls not bad, but you really have to rev it over 4500rpm to feel it. I had 204hp E90 diesel and no joking but it felt quicker as a daily driver because turbo was nicely massaging your back from 2k rpm (E90 had 7.4s to 62mph where Z4 has 7.0s).
If 3.0i behaves the same way, then I was just expecting something unreal. If 3.0i is noticeably quicker (which I believe because it's 5.9s to 62mph) then I am dreaming about 3.0 since my first 5 minutes of owning 2.5i :|. Now I can't imagine having 2.0i or 2.2i unless you don't care at all ;P
Let's forget about the engine! The car is pretty well equipped:
-Sat Nav
-Leather seats heated, electric with memory
-HiFi System Proffessional DSP
-Xenon Lights with celaning system
-Cruise control
-Fold in mirrors with auto dip
-CD Changer for 6 CD's
-PDC rear
The car has 15 years and over 100k miles but interior is in very good shape! Plastics doesn't crack, leather seats are in good shape with no wear or tear.
I have couple things to do:
-Headlight restore
-refreshing the interior (I will clean the seats and all the plastics although they does not seem to be dirty)
-Oil service
Some mods planned:
-I have to be able to play music from my Iphone. I don't know right now what's the best solution and I know that there is a lot about it on the forum so I will read it all and chose something. I will add AUX or I will buy some module which allows to connect an iphone via bluetooth - what do you reccomend?
-I will think about changing the steering wheel to the multifunction one with ability to change tracks from it
-I have to install a dash camera (I think there is a DIY manual how to take a power from the light above the head on the forum so I will follow it)
-I will remove CDV probably
-I need to read if it's possible in my model to open/close the roof using the key
-Sat Nav
-Cruise control
-PDC rear
-Headlight restore
-Oil service
Some mods planned:
