Firstly I have searched the forum and can confirm:
- this is not a stuck-in gold pin / release valve problem
- this is not a shelf switch problem
- the pin inside the roof motor that spins the white plastic wheel is in place
- this is not a motor problem (brand new roof motor, spinning fiercely in both directions for the first time in a while!)
- the hydraulic lines are paired correctly (is it possible to have them organised incorrectly on the correct screw? not sure...)
- the +ve / -ve are connected and have experimented with swapping
- there is enough oil in the reservoir (have tried over-filling too to no avail too)
So what's my problem? The bloody roof doesn't work of course! AGAIN!
It unlocks, motor kicks into life and nothing happens.
To open I have to hold the open button and push the roof upwards, then with it's own weight it falls backwards and down. But once open, the roof does not close. To close the roof I have to have a second pair of hands push the golden pin and pull the roof up and close with my hands
To me it seems like there is no change in hydraulic pressure at within the hydraulic system when pushing the open / close buttons.
I notice that the level of oil inside the reservoir doesn't seem to decrease / increase either
So I wonder what the problem might be?
I really am at a loss as to what is going wrong...
