Issue with passenger window when closing top
Visionist
When I close my top, the passenger window closes all the way like the others then retracts almost a third of the way down again. It's been doing it for a few days.
Is this a coded function I might have triggered somehow? Cheers
Shouldn't be happening! Can you close it again manually using the window switch?
It's the anti trap. There's both a software fix and also a hardware relay fix for this. Speak with your dealer.
Can also be triggered by excess friction causing greater current draw activating the anti trap,
mine did this & after cleaning the accumulated grunge from the rubber window seal with a toothbrush & soapy water I sprayed some silicone spray judicially around, re taught the window & it's been ok since :thumbsup:
Regards
Try a window memory reset, doors shut, from the driver window control, press and hold down button for 5 seconds after window reaches bottom, the raise window all the way up :thumbsup:
Reset the switch and it works properly now. :thumbsup: Funny how the rears have no anti-trap/one touch up. Is it because they're out of the driver's line of sight? Even the new S Coupe, all one hundred grand of it (baseline unequipped) "features" this same oversight. Pffft.
