Is this guy nuts or what?
Trajan
 SE PA
http://forums.noria.com/eve/forums?a=tpc&s=692608715&f=616604995&m=895104684&r=169101305#169101305
Miro Kefurt states:
We have hundreds of BMW customers about 1/2 of them swithced to SynLube at very low mileage typically before the first oil change (BECAUSE THE free SERVICE WAS JUST TOO much hastle, like coming back to pick up the car 4 hours later only to find it was not even toucvhed yet) - and with engines from 4 cylinder to 12 cylnder and they all go at least 16,000 miles before adding any oil (and most never fo between filter changes at 25,000 miles intervals). Then the other half switched AFTER the free BMW maintenance was over, or when they bought USED BMW (like Trajan did) and their oil consumption on the SAME ENGINES in SAME MY use as much as quart every 3,000 miles - which of course BMW claims is quite fine AND NORMAL !!!
So the problem really is that the FREE maintenance with the Glorified ZERO W Motor Oil causes so much wear in the 50,000 miles or 4 years that it turns ANY BMW engine in USA into Oil Burner.
And it is not one case in few hundred but 1/2 of the few hundred.
The BMW engines in Rolls Royces are the ones that get worn out the most.
So if you think the BMW Dealers use the best there is for their FREE service bit, perhaps you should do VOA on both the bottle and the stuff they pump in - I can make almost certain bet that the two are not the same, they probably use SA oil and just pocket the $75 from BMW that they get for OIL, FILTER and LABOR which probably is not enough to cover the genuine stuff.
Amazingly only MINI Dealers for most part seem to use good oil or else that NON BMW engine is more tollerant of poor quality oil.
Germans simple are not capable to make engines that do not burn oil - for PORSCHE 600 to 900 miles to a quart is OK and it is the only car in the world that has OIL LEVEL GAUGE (911) there sure is a reason why even with 14 Liters of oil it is needed !!!
In case you're wondering who this is, check his site: http://www.synlube.com/
An "oil" you never change.......
Got a bit lost in reading this (an age thing....) but I think the suggestion is in the quoted article that people change to SYNLUBE - a lubricant for life, i.e. just top ups and no change for the life of the vehicle! Now it may be that the oil companies are trying to suppress such a product so that we continue to hand over our hard earned for their products on a regular basis. Me I will keep handing over the hard earned dosh. As for oils used in BMW servicing (the first one or subsequent services) I ask and it's confirmed on the invoice exactly what oil has been used and that's good enough for me. All engines burn a degree of oil some slightly more than others and this is why a running in period is critical to ensure all engine parts bed in a the same rate. SYNLUBE - certainly not for me.
Well, to hopefully clear it up a bit.
In the above rant, he claims your bimmer is filled with 0w oil.
That your dealer fills it with SA oil, a very old and obsolete formulation.
That many switch to said oil that only comes in a 5w-50 and is $32 per quart because they don't like waiting for the service. (he thinks all a dealer does is change oil while under warranty.)
He rants in part because I exposed his "oil" for the scam that it is. (He claims it's made in Mercury, Nevada, which is closed to the general public.)
